no display .. then fan run hig speed..Please try this file
i check it. im sure that is my back up.. what i should do? i just flash the unlock file. and now the laptop is no display..that file is new and exact file for this model and should work
check it more
005: Align to the bottom of ZIF,disable placed at random function.try this one
hineed help to unlock my bios.. thank you
thank you.. i will check it now.. let me show you the reading in oscilloscope.. i know im out of the topic in the section.. im sorry for that.. thank you for your consideration.hi
if you programed bios with old backup and system still have problem in booting , i guess system have different problem and bios file don't have problem
you must check the voltages and other things .
example : check the components around the bios ic .
Since the device does not turn off , i guess io has a problem . maybe when the system is on you have Screwed up![]()
can i have clear me for this file it has 90s delaytry this one
AB WALI , jeremyadams , user1252 , user60189 , Vahab Hemmati , user46560 , 14Darkmotives , basify , sware , Oscar Sanchez , Errorkart , samemuro , Ali Shaikh , Hosein Asadolahi , aliali , msk-hp9 , gullu , user61919 , hsuhuichou , BAB AL HASOOB , NJAKA , Mbuch , user57790 , sultan321 , Daniel melkamu , user55973 , LEONCE , Nassim I , Godslove , Rohit suthar , asraf ali , user57764 , Ticha technologies , ELEVETUS TECH , user21952 , megaglobal12 , user57871 , Asghar ali , malik87300 , SSV , ACHOTHANI , shoaib567 , amkam11 , user54378
