Run Your Repair Shop Like a Pro!
Finty is the all-in-one software for laptop repair shops — print repair ticket & invoices in 21 languages.
Dell BIOS Beep Codes
Founder
Dell BIOS Beep Codes:
Beep Codes
Possible Causes
Corrective Action
1 - 2
No video card detected
Reseat the video card
1 - 2 - 2 - 3
BIOS ROM checksum error
1 - 3 - 1 - 1
DRAM refresh error
Reseat the memory modules
1 - 3 - 1 - 3
8742 Keyboard Controller error
Reseat the keyboard connector
1 - 3 - 3 - 1
Memory defective or not present
1 - 3 - 4 - 1
RAM failure on line xxx
1 - 3 - 4 - 3
RAM failure on data bits xxx of low byte on memory bus
1 - 4 - 1 - 1
RAM failure on data bits xxx of high byte on memory bus
Dell BIOS System Messages:
Message
Possible Cause
Corrective Action
nnnn Cache RAM Passed
nnnn KB of system cache RAM has been successfully tested
nnnn Extended RAM Passed
nnnn KB of extended RAM has been tested
nnnn Shadow RAM Passed
nnnn KB of shadow RAM has been successfully tested
nnnn System RAM Passed
nnnn KB of system RAM has been successfully tested
CD-ROM drive Identified
The systems automatic drive type detection feature has identified the CD-ROM drive
Diskette drive A error; Diskette drive B Error
Drive A or B is present but has failed the BIOS POST
Ensure that the drive is installed correctly in the chassis and detected correctly in the system setup
Entering Setup
The system is starting the system setup program
Extended RAM Failed at offset: nnnn
Extended memory is not working correctly or is not configured correctly at offset: nnnn
IF you receive this message after making changes in the system setup program, enter the program and restore the original value(s)
Failing bits: nnnn
nnnn is a map of the bits at RAM address that failed the memory test. Each 1 in the map indicates a failed bit
If you receive this message after making changes in the system setup program, enter the program and restore the original value(s)
Fixed Disk n Failure; Fixed Disk Controller Failure
The hard drive specified by n is not working or not configured correctly
Ensure that the drive is installed correctly in the chassis and defined coracle in the system setup program
Fixed Disk n Identified
The system's automatic drive type detection feature has identified the hard disk drive(s)
Incorrect Drive x type - Run Setup
Diskette drive x is not correctly identified in the system setup program
Ensure that the drive is defined correctly in the system setup program
Invalid NVRAM media type
The system is having a problem accessing NVRAM (CMOS)
Set the configuration jumper to Maintenance mode and restart the system to return all settings to their defaults
Invalid system configuration data
The system configuration information is the system setup program is incorrect, or the battery charge may be low
Enter the system setup program and verify the system configuration, then restart the system
Keyboard controller error
The keyboard controller failed it's test
Keyboard error
The keyboard is not working correctly
The keyboard or system board may need to be replaced
Keyboard error nn
The BIOS has detected a stuck key represented by scan code nn
Make sure nothing is resting on the keyboard. If a key appears to be stuck, carefully pry it up. if the problem persists, you may need to replace the keyboard
Mouse initialized
The system's mouse has been found and initialized
Operating system not found
The operating system cannot be located on drive A or drive C
Enter the system setup program and confirm that drive A or drive C is properly identified
Parity check 1 nnnn
A parity error has been detected on the system bus. The BIOS attempts to locate the address and display it nnnn. If it cannot locate the address, it displays ???? instead
If you receive this message after making changes in the setup program, enter the program and restore the original values(s)
Parity check 2 nnnn
A parity error has been detected on the I/O bus. The BIOS attempts to locate the address and display it nnnn. If it cannot locate the address, it displays ???? instead
Press <F1> to resume, <F2> to Setup
This message is displayed after a recoverable error message
Press <F1> to start the boot routine or <F2> to enter the system setup program and change any settings
Press <Del> to enter SETUP
Optional message displayed during POST
Id desired, press <Del> to enter the system setup program
Previous boot incomplete - Default configuration used
After a unsuccessful boot, POST loads default values
There may be incorrect values or incorrect settings in the system setup program. Run the system setup program and attempt to restore the incorrect settings. If the message reappears, set the configuration jumper to Maintenance mode and restart the system to return all settings to their defaults
Real time clock error
The RTC has failed the BIOS test
Resource allocation conflict on motherboard
The system cannot configure all system board devices without a resource conflict
Run the system setup program and try to resolve any obvious resource conflicts. If the message reappears, set the configuration jumper to Maintenance mode and restart the system to return all settings to their defaults
Shadow RAM failed at offset: nnnn
Shadow RAM has failed at offset nnnn in the 64KB block in which the error was detected
System battery is dead - Replace and run SETUP
The CMOS clock battery indicator shows the battery is dead
Replace the battery and run the system setup program to reconfigure the system
System BIOS shadowed
The system BIOS has been copied to shadow RAM
System cache error - cache disabled
RAM cache failed the BIOS test. The BIOS has disabled the cache
If you receive this message after making changes in the system setup program, enter the program and restore the original settings
System CMOS checksum bad - run SETUP
System CMOS has been corrupted or modified incorrectly, perhaps by an application program that changes data stored in CMOS
Run the system setup program and reconfigure the system by either reverting to the default values or by making your own selections
System RAM failed at offset: nnnn
System RAM failed at offset nnnn in the 64KB block in which the error was detected
System timer error
The timer test failed
UMB Upper limit segment address: nnnn
Displays the address nnnn of the upper limit of the UMB, indicating released segments of the BIOS which may be reclaimed by a virtual memory manager
Video BIOS shadowed
The video BIOS has been successfully copied to shadow RAM
Dell BIOS Post Codes:
01
CPU register test in progress
02
CMOS read/write test failed
03
BIOS ROM checksum bad
04
8254 programmable interrupt controller failed
05
DMA controller initialization failed
06
DMA page-register test failed
08
RAM refresh verification failed
09
Starting first-64K RAM test
0A
First-64KB RAM IC or data line bad
0B
First-64KB RAM odd/even logic bad
0C
First-64KB address line bad
0D
First-64KB parity error
10
Bit 0 bad in first 64KB
11
Bit 1 bad in first 64KB
12
Bit 2 bad in first 64KB
13
Bit 3 bad in first 64KB
14
Bit 4 bad in first 64KB
15
Bit 5 bad in first 64KB
16
Bit 6 bad in first 64KB
17
Bit 7 bad in first 64KB
18
Bit 8 bad in first 64KB
19
Bit 9 bad in first 64KB
1A
Bit 10 bad in first 64KB
1B
Bit 11 bad in first 64KB
1C
Bit 12 bad in first 64KB
1D
Bit 13 bad in first 64KB
1E
Bit 14 bad in first 64KB
1F
Bit 15 bad in first 64KB
20
Slave DMA register bad
21
Master DMA register bad
22
Master interrupt-mask register bad
23
Slave interrupt-mask register bad
25
Loading interrupt vectors
27
Keyboard-controller test failed
28
CMOS RAM battery bad
29
CMOS configuration validation in progress
2B
Video-memory test failed
2C
Video initialization failure
2D
Video-retrace failure
2E
Searching for a video ROM
30
Switching to video ROM
31
Monochrome operation OK
32
Color (CGA) operation OK
33
Color operation OK
34
Timer-tick interrupt in progress (or bad)
35
CMOS shutdown test in progress (or bad)
36
Gate A20 bad
37
Unexpected interrupt in protected mode
38
RAM test in progress or high address line is bad
3A
Interval timer channel 2 bad
3B
Time-of-day test bad
3C
Serial-port test bad
3D
Parallel -port test bad
3E
Math co-processor test bad
3F
Cache-memory test bad
