Tutorial Videos Repairing Lenovo G510 No Display Problem Using Vertyanov Debugger
This programmer is the new version of the late programmers and it's very easy to work with it. It's not manual; it means by the use of its software, you can connect I/O pins to keyboard connector.
In revision 5.1 there was added an option to firmware ITE multiple controllers. Test were done on ITE8586, ITE8580, ITE8585,other multiple controllers will operate and will be added after tests. ITE mode is working only through keyboard module.
In order to connect its necessary to select all pins listed on the right, in the menu Select the motherboard its necessary to choose added motherboard and only after this to provide power supply.
It’s necessary to activate operation mode with ITE multiple controllers, the cost of activation is 10$, for the actions there should be send a file serial.ini by e-mail and you will receive file for activation after payment.
In revision 4.1 there was added an option to firmware multiple controllers as MEC1609, MEC1619. Pin F4(Boot_Mode#) to be installed as 0 (gnd). Pin M8(nFWP) blocks recording and deleting of boot and info. The blocking is active when it’s connected to gnd, when its connected to 3.3В then the blocking is deactivated.
There was added an option to firmware spi flesh drive through ENE multiple controllers without unsoldering, as well an option to firmware RTD2120L, monitor’s processor. It’s possible to firmware spi flesh drives and the base will be updated.
  • How to Program KBC ENE9012 with SVOD Programer-EN_2.zip
Founder
Whether SVOD programmer are able to programme ite8585e? this is the questions of many repir person and they wanted to be sure about it. Today we are going to show in this tutorial video , how to programme IC I/O ite8585e on ASUS x552 and how to connect correctly.
Some of our colleagues contacted and have faced problem while reading IC I/O it gives 3.0.0 error. Here we are going to reveal the cause and how to solve this error.
SVOD programmer is updating day to day and except ite 8585e and ite 8586e can programme other new ,models of ite and it add to database of SVOD. We are gathering this list and will provide you as soon as possible.
ALL The Best! :)
  • how to program ITE 8585e with svod programer.rar
Founder
In this tutorial video, you get to know how to program IC/IO by TNM5000 programmer. Hope you enjoy watching this video and watch our other videos and we are looking forward for your feedbacks.
  • tnm5000_kb9012EN.zip
Founder
SVOD programmer and how to program IC I/O
Here in this video you will learn about how to use SVOD programmer!
This tutorial video educate step by step the process of programming IC I/O
This SVOD programmer supports these series of IC I/O:
ENE KB90xx, ITE8586, ITE8580, ITE8585, MEC1609, MEC1619
We will post the list of IC I/O which this programmer supports in its next update.
We thank from our friend Hosein, who helped us in preparing this tutorial video.
  • how-to-use-SVOD-Programmer.zip
Founder
This video is: How to use SVOD programmer from a to z…
I suggest watching the video, for those who wanna buy the programmer and the ones who already have it. It consists of the topics bellow:
  • Programmer introduction
  • The use of SVOD programmer in laptop repairing
  • When to program IO?
  • How to connect SVOD programmer and start to work
  • Describe software environment
  • Pins config and explain about online Database/ check the safety of online Database pins config
  • List of programmable ICs
  • How to connect 1.00 mm and 0.8 mm flat cable
  • How to read ENE and ITE by programmer
  • How to add ENE manually by buzzer
  • How to add ITE manually by buzzer
  • How to connect pins via schematics
  • New zif introduction
  • The use of zif in laptop repairing, and its weak and strong points
  • How to read and program ENE and ITE by zif
  • Common errors
It is recorded by Dr-Bios technical team and is 60 mins.
Hope you enjoy
  • svod_a-z.zip
  • svod_a-z.part1.rar
  • svod_a-z.part2.rar
  • svod_a-z.part3.rar
  • svod_a-z.part4.rar
Founder
This video is captured for those who have SVOD programmer and want to run it in windows 10-64 bit. All the steps are shown and explained.
  • How_to_install_SVOD_programmer_driver_in_Windows_10_EN.zip
Founder
Today I’ll introduce a capability of SVOD programmer. You might have come across this problem “some keyboard keys won’t work after changing IO”. And you might wonder if the problem is caused by keyboard or IO isn’t properly connected to the board.
In this video, you can see how to realize if the problem is IO or keyboard?
Stay with Dr-Bios.com
  • TEST KEYBOARD WITH SVOD.zip
Founder
Who can use I/O programmer?
I/O programmers are usable for all laptop repairmen!
Theres a revolution in laptop motherboards since 2012. If you are asking what kind of revolution is it, keep reading this article. EC IC that has 8 pins and placed next to the south bridge, is been removed!
So, where did that IC go?!
All the important data from EC IC, transferred into the I/O IC. Inside IO microcontroller, a new block added, called EC and so the EC data should be programmed there! Also, while im writing this article, these EC files which transferred into microcontrollers, are 128 KB and their newer versions are 192 KB.
Therefore: most of today’s laptops, beside their bios files, their EC files which is on I/O micro controller, should be programmed.
And to read the article about IOs with which number are/aren’t programmable.
How to program microcontrollers or IO?
To program these kind of microcontrollers you can use some tools like: TNM5000, SVOD PROGRAMMER , VERTYANOV PROGRAMMER , RT809 PROGRAMMER
Each of these programmers have their own specific features and we’ll share more information about them later. But we shared some related articles so far, which might help you:
How to program IO IC with tnm5000
A-Z about SVOD programmer
How to test the keyboard with SVOD programmer
Well, in this article we are going to talk about Vertyanov programmer and its features and possibilities:
Vertyanov programmer is a programmer that made in Russia and Dr Bios has its partnership selling in Iran. You can contact us to order it.
With this Vertyanov programmer, you can program without need to soldering or removing IO IC. but How?
There is some flat cables with Vertyanov programmer and due to laptop motherboard model, you need to connect it to the keyboard connector and then run the software, so you can easily program the EC files and data on these microcontrollers.
Where can I download IC I/O files?
If you need any IO file, you can go to laptop bios and you need to select brand of your laptop. Files with 128KB or 192 KB at their end, they are IO files and they are special to program. Also there are some files beside Bios’ IC, like 8MB Bios + EC 128KB, that means there is a 8MB file for Bios and there is a 128 KB for IO.
What kind of microcontrollers Vertyanov programmer can program?
We can say every kinds of microcontrollers Vertyanov programmer can program! It can easily program ENE,ITE,MEC,NUVUTON series of microcontroller.
What kind of motherboards’ IO IC you can program with Vertyanov programmer?
For example, to program KB9012 on a motherboard which is definitely programmable, you need to have 3.3 voltage on IO pin or somehow send 3.3 voltage to IO, otherwise none of programmers can program the IC without 3.3 voltage.
So before connect the programmer to the device, make sure you have 3.3 voltage on IO pin already! Vertyanov programmer is a specialized programmer for IC/IO. Let me make it easier, you cant program 4MB or 8MB Bios IC with Vertyanov programmer. To program Bios we recommend you to use TNM5000 which you can order it from Dr Bios.
EEPROM LCD,LED Programing features with Vertyanov programmer:
In LCD,LED monitors there is one or two programmable IC, and you can solve white screen and ... with programming this IC .
You don’t need to solder or remove IC from the board by the way.
Features of testing keyboard by Vertyanov programmer:
Most of the time, when you replace or change IO IC , you will see some keyboard’s buttons, are not working well, it’s a bit difficult to diagnose if this problem is caused by keyboard controller or due to the keyboard itself! In these cases, you need to separate the keyboard and then connect the keyboard flat to Vertyanov programmer, and select keyboard testing in software menu and you’ll see possibility of keyboard testing is so easily!
There are some other cables beside programmer, to program IC s which need to program or reset by jTAG that mostly related to MEC microcontrollers (if we get or receive this kind of motherboard we’ll share a video about how to use the cables).
Do you have to pay for licensing or programmer software activation?
Nope! Software updates are always available and you can download and install them for free.
Support and Vertyanov programmer’s guarantee :
We have 6 months of Dr Bios’ guarantee + free educating and free videos about how to use and work with this programmer.
Where is Vertyanov programmer made in?
Vertyanov programmer is made in Russia and I guarantee its PCB has high quality.
what about Vertyanov programmer's software and its interface?
Its interface is as simple as you can imagine! Its so easy to work with and all of errors and messages you’ll get while working with it, will help you to solve the problem so very easily.
what is Vertyanov programmer's software language?
Its official language is English and its easy and understandable as we said so.
Download Vertyanov Software:
Download tutorial video of working with Vertyanov programmer:
We have uploaded a tutorial video about how to work with this programmer and its qualities about all the features we talked about it in this article.
Download tutorial video of Programming LED-LCD Eeprom with Vertyanov programmer:
Download tutorial video of laptop keyboard test with Vertyanov programmer:
What is the usage of programmer’s socket and ZIF?
We told earlier you cant program IO if you don’t have 3.3 voltage in board! So there are some ways to give that 3.3 voltage and one of these ways is using Vertyanov programmer’s special ZIF.
With this ZIF you can program IO in 2 ways:
1 . remove IO from motherboard and solder it on special ZIF named SPIDER and then program it.
2 . remove IO from motherboard and put it on ZIF named JAWS without soldering and then program it.
You can use these 2 ways only when you don’t have 3.3 voltage in motherboard.
at the end you can see photos of ZIF component which we even talked about them in tutorial video
smiley
Feel free to ask any question about programmers and how to use them.
Good luck and have a nice day/night
  • DR-BIOS.COM_Vertyanov_JIG_Ver_5.4.zip
  • How_to_Program_LED-LCD_Eeprom_with_Vertyanov_Programmer_EN.zip
  • How_to_Use_Vertyanov_Programmer_EN.zip
  • Laptop_Keyoboard_Test_with_Vertyanov_Programmer_EN.zip
Founder
There is a new programmer called Vertyanov. The name sounds Russian.
Yes the Vertyanov programmer is Russian :)
In the video bellow, all the information and details of how to use the programmer are shown.
You can see how to use this programmer to Read and Write IT8586E, program all IOs including ENE, ITE, MEC, NUVOTON, Read and Write many types of LCD and LED EEPROM, and also how to test laptop keyboard.
Stay with us
Video Size: 270 MB
Video Time: 17:22 min
  • How_to_program_ITE_IO_with_Vertyanov_Programmer_EN.zip
Founder
23000 Supported Devices Flash Memory (Parallel / Nand /Serial) , EPROM , EEPROM , Serial EEPROM , Microcontroller , NVRAM , FRAM , CPLD , PLD , FPGA).
  • 48-Pins ZIF Socket with Pin Continuity tester & 10-Pins ISP/JTAG Connector.
  • USB 2.0 High Speed ,Program 1 Gbit Nand Flash less than 50 sec , Reading Serial Flash memory with 6 Mbit/Sec Speed.
  • Auto detection of all flash Memories/Microcontrollers with Device ID.
  • User friendly software for Windows XP/VISTA/7/8 (32,64 bits).
  • Multiple Programming is possible by attaching 2 or more Programmers to one PC.
  • Very low cost Main Unit & Low cost adaptors.
  • Special Abilities like, Altera US,B-B.l*a*s.ter Emulation for Quartus Software, Serial Port Emulation , Vehicle ECU , Immoblizer & Dashboard microcontroller Support.
TNM5000 Programmer is very fast , Low cost , High performance Universal Programmer , specially designed for supporting Flash memories , Nand flashes , Serial EEPROMS , Microcontrollers & Automotive ECU , Dashboard parts.
The Heart of TNM5000 is a 500.0000 Gate FPGA with a designed CPU core with 96MHz Clock for fast programming of chips.
Parallel Flash Memories: up to 56 pins parallel flash memories are supported by TNM5000. it Supports different kind of packages (PLCC , TSOP1 , TSOP2 ,VSOP & ...). All Flashes can be automatically detected by software in case of unreadable device names. By using a single adaptor for all 32-48 pins TSOP flashes , user only need 1 adaptor for over 2000 flash chips.
Nand Flash Memories: TNM5000 has an additional Nand+ software , specially designed for Nand flash memories. Nand+ Software has one of the most complete list of Nand flash Memories with algorithms for correction of bad data in MLC Nand Flashes. TNM5000 is one of the fastest Nand Programmers in the world with Read & Write Speed up to 8 MegaByte per Second. All Nand Flashes can be automatically detected by software in case of unreadable or remarked device names.
Serial Flash Memories: All 8-16 Pins Serial SPI flash memories are supported by TNM5000. All SPI flash Memories can be detected automatically by software in case of unreadable device names. It reads & programs SPi flashes with maximum safe speed on ZIF (6-7 Mbit/second) . Also it Unprotects the write protected flashes before writing data to it.
Microcontrollers:
ATMEL: All AVR 8 bits chips (ATMEGA/ATTINY/AT90S) are supported on ZIF Scocket & by ISP cable. High Voltage Parallel on ZIF Programming of AVR up to 64 pins is supported. newly introduced ATXMEGA Series are supported by both PDI & JTAG Method. Old C51 series & new single cycle C51 series are completely supported. All the above series can be detected automatically by TNM5000. ARM7 programming by JTAG is supported.
Microchip: One of the most complete device list for microchip PIC microcontrollers including all PIC12F /PIC12C /PIC16C / PIC16F / PIC18F / DPIC33F / J & K Series. Devices up to 40 Pins can be programmed on ZIF , All PICs can be detected automatically & programmed by ISP cable.
Others: ST, SST, Philips (NXP) , Motorola , Syncmos, Silicon Lab , ICSI , Infineon , Intel , Winbond & ...
Automotive MCUs: Supporting of ST10F & TMS370 Series by ISP cable for many BOSCH/VALEO/SAGEM ECUs (complete ST10F support of XPROG-m programmer device list). supporting of siemense & infineon SAK-C167 connected to 44 or 48 pins flash (Siemense/BOSCH/SAGEM S2000 ECU) like HSE FlasHit Programmer. Supporting NEC & Motorola Devices for Dashboards.
PLD/CPLD/FPGA: Supporting All ALTERA JTAG Devices by emulation of USB B l a s t e r Programmer in Quartus Software. Supporting of Xilinx CPLD/FPGA with jed file. Fast Xilinx FPGA configuration with bit file. Supporting of GAL/PALCE Devices with special option for PALCE unlocking.
Software: With multiple language support (English / Chinese / Russian /polska /Arabic / French /FARSI). More languages & Devices can be added by customer request. You Can Download Software & run it in Demo mode to evaluate it.
ADAPTORS: We have a policy for minimum price for adaptors, our adaptors can be used for many different packages. In many cases we support other programmer manufacturers adaptors on our device. Here are example of some of our adaptors:
For All 32/40/48 Pins TSOP Type-1 (20mm Pin-Pin Lenght) , You Need Only one adaptor Model 548T2
For All 56 Pins TSOP Type-1 (20mm Pin-Pin Lenght) , You Need Only one adaptor Model 556T2 , with different sets of bottom plates which can be easily exchanged by user .
English User Manual
Updated: Jan 3, 2017
Universal Programmer Model 5000
Win XP /2000 /VISTA /Windows 7 /Windows 8 /Windows 10 (32-64 bits) Install CD-ROM software
Version: 9.75 Updated: Aug 10, 2016
  • Prog_Manual.pdf
Founder
As you may remember, we posted several articles about BGA machines and their function, equipment, accessories and explained their descriptions. But in this video, we would like to talk more specifically about one of them, WDS-620 BGA machine. And tell you that Dr-Bios.com is its distributor and if you’d like to buy it contact us on Skype: Dr.Bios2015
This BGA machine is for small, medium and large PC, laptop and mobile boards. You can use it to remove, place, replace, renew tin,.. of motherboards’ different sized chips, IO, memory, Ram..
This machine has 5 modes: Remove, Weld, Manual, Semi Auto, Mount. All of the modes are explained in the video. Another thing you’ll see is that we will introduce each component, button, knob and accessory that comes with the machine, BUT working and setting the machine requires another video which we will capture soon as well.
It will be sent directly from China, you can order with 2 ways: Sea shipping and Airmail.
Let’s have a closer look and find out more about this machine in the video bellow.
Stay with Dr-Bios.com :)
Review WDS-620 BGA ReworkStation
26:00 Minute, Full HD Video (395 MB)
  • Introduction_of_WDS-620_BGA_Rework_Station.zip
Founder
This is the new update of SVOD programmer and every time the company shares new updates for the software, we will put it in here (this article will be updated once the new update for the software is released)
As you know you can program different kinds of I/O such as: ITE, NUVOTON, ENE, MEC with this programmer. And it has the capability of testing keyboards as well.
Version 9.0.04 of SVOD programmer ( Attached )
Founder
From now on we will put Vertyanov programmer’s new updates in this article and every time there is a new version we will update this article.
As you know Vertyanov programmer can program different kinds of I/O such as: ITE, NUVOTON, ENE, MEC, it can also test keyboards. And another feature is that it can program LED and LCD (EEPROM).
Vertyanov Ver 3.x Software Download
Release date : 2018.09.22
Release update: 2018.07.19
Release date : 2018.06.12
  • Dr-Bios.com_Vertyanov_JIG_ver_3.X_09222018.zip
  • DR-BIOS.COM_Vertyanov_JIG_ver-3.X.zip
  • Vertyanov_JIG_ver-3.X.rar
Founder
Today I have Lenovo G510 laptop which turns ON but there is no display. As you know, not displaying image on the screen or the “No Display” problem can be caused by both voltages and signals. In this video, I check both the voltages and the signals to solve no display problem. I troubleshoot the motherboard using Vertyanov debugger and solve the problem.
Stay with us ;)
Video Size: 865MB
Video Time: 18 Min
  • How_to_Repair_Lenovo_G510_Laptop_Using_Debugger.part1.rar
  • How_to_Repair_Lenovo_G510_Laptop_Using_Debugger.part2.rar
Patrick Ribbsaeter
Lagadatorumea
smiley
The links on this page for these doesn't work: Please check master. thank you!
Dulur , arman102 , Copper Lines Infotech , ARGPH2020 , user44940 , user61478 , arjwen , nassarraouf , orlando65 , zeland8 , gayan123 , Cucuk Sugiarto , halit , JonC , , mrwahab , vicsem73 , lord81 , user61870 , kouji-n , wiwin , user51130 , Ismail-U50 , , Micro-computers , Mom chanto , bdany , Anwar1982 , opista , azor82 , eoprava , armanuddin , kutay , quocdien , PNad , zinmina , user1269 , ebubekir soyalp , user22300 , mista , IT Repair , Blaise , Nothing , screentechs , user55610 , berkahbintang888 , ose , nestor , Badreddine , ranjan8750 , famory , Brandon coder , Joan1955 , ProtocalElectronics , johnllagas , wayanbunga , OksanaAssed , user18370 , Jolex72 , delp , sameerahmad93 , user4344 , Rohit suthar , Ipart , Amit123 , rejiambalil , BISWA , amnaelmasreya , purwanto , user55722 , Vasis , marufpatowary , Alamgir , zertuche , Conanb77 , user14348 , sello , manash0591 , NASRO , DVlad , Teamplasmaph , user4913 , jkliensabio252721 , samkelo , user5952 , kocayunus , user51120 , Descharge , leo24661 , Xidox75 , oluwafemiakolade , user20120 , nadeem , ringomega , Ashmak , Hamidrezaghanei , Largo21 , user18515 , zirla , zsombi03 , nasirdanish , RAIN , rar123 , rajsolutionsura , user18903 , florindecada , francisnonso1 , user4155 , nario88 , Willie , user26471 , vig0esh , sultan321 , user57416 , ppggrzegorz , KEKEC3778 , destinycenter , user24003 , softtec , bilalinfotex , danel32 , zensar , user24229 , EdwinUsady , EkoSetyono , tolgaakbasak , angin8805 , klauscx650 , Nester449 , SialisshopNep , dogu06 , mariusz35 , Rogerrem , Ahmed kari , Tweedlex , samemuro , Metal reuse center , Redit404 , grzes501 , alexv1new , hairulole , LAEngineeringElectronics , drmiki25 , leulseged , haminhtan
